Liked 1,880 Times in 422 Posts
What you'd look for when dyno testing headers would be average torque and horsepower through the RPM range you're running. You'd also want to look at the acceleration rate you test at. You have at least 3 different acceleration rates, if you have a 3 speed transmission, and that does not account for the fact that once you shift from first to second, from there on, your acceleration rate (in RPM per minute) slows at a progressive rate, the higher the gear, the slower the acceleration rate.
Alan Roehrich 212A G/S |
Liked 9 Times in 3 Posts
a dyno is the only repeatable situation.......I know there are many who would rather make a million runs on the car and put more variables to see if a header is any better than another.....
dyno is much more affordable in my book...... |
#3 | |
reed |
