Liked 9 Times in 8 Posts
Are Titan pumps legal?
351C |
Liked 4 Times in 3 Posts
We just signed up with Schumann as a distributor at the PRI show :-)
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
Schumann makes a very good oil pump, I've been using them for a while now. Much better than Melling, it is sad how far Melling has fallen, they once made a fine product, now all they care about is cost. The standard M55 small block pump they make is known far and wide for breaking. I won't even buy one now, the last one I bought was so weak it broke installing their own pick up. I'm not even real sure of the Moroso pumps, because they're a blueprinted Melling. At one time, that was fine. Now? Not so much.
Clay Valley Racing also makes a nice, albeit pricey, wet sump pump.
Alan Roehrich 212A G/S |
Any internal, wet sump oil pump is legal, including the Titan.
Nevertheless, for the price, a Schumman pump will do the job and more. By the way, in another website you posted details about your choice for your Stocker cylinder head components. Therefore, it appears you have chosen a hollow stem intake valve that would make your heads illegal. Just saying... |
#5 | |
Ford did make 2 valves for the 351C (D0ZX6507A) are hollow stem/stainless steel with 11/32-inch stems (DOZX6505A) is a sodium filled 1.71 exhaust valve with 11/32 stems You did notice that the 11/32 hollow stem Ferrea intakes that I am using are not sodium filled and the 11/32 Ferrea exhaust that I am using are solid stem correct? Just thought I would clear that up Thanks for noticing though Bill Last edited by Bill Diehl; 01-05-2014 at 08:31 PM. |
