#21 |
Liked 520 Times in 132 Posts
Well I still have a problem. Engine does sound ok now with the new box. Had MSD make up some new wires. Left at 8800 and it pulled it down to 5000. Clutch only has two turns. So we put the clutch on zero turns and well see tommorow. If that doesn't do it were out of here. Dyno time next week. I'll post more pic tonight. Ed
#22 |
Liked 254 Times in 78 Posts
Ed,
Had similar problem once, the bottom of the intake manifold was just barely bottoming out on the block, and under load the car would not run.Idling and burnouts were fine. Intake manifold gaskets looked compressed. We happened to lay the intake on the motor without any gaskets and noticed the manifold sides were not touching the heads at all, milled some off bottom of the intake on the ends and problem was solved. |
#23 |
Ed, Thanks for the great pictures. I hope you get rid of the bad luck soon. Have you checked the fuel system? If its starving for fuel it won't carry a load, but may sound fine otherwise.
4878 SS/GA 66CHEVY II |
#24 |
Liked 60 Times in 12 Posts
Take off the alternator belt, and do the flow test with the fuel system, now. You might find something.
2894 STK |
#25 | |
Liked 5 Times in 2 Posts
Good luck, you'll get it figured out.
Brett Brown 7257 STK, SS, COMP |
#26 |
Sorry I simply didn't have time today to to get pictures or much else. We have tried everything and then some to fix our problem without success. Going to try to forget about it enjoy the races tommorow and head to the house. I'm going to pull the engine on monday and my son will dyno it. Then I will know if it's the engine or the car. I'll try to get the rest of the pictures tommorow of cars I missed.
#27 |
Liked 325 Times in 50 Posts
Looking at the Sat. plan, I think you guys gonna be late. One round stock, three rounds of ss class, throw in a super class or two, and a top dragster hit, all by 10:30, and 4 rounds of ss by 8 pm. Yall gonna be late.
Jeff Teuton 4022 STK |
#28 |
Liked 10,838 Times in 2,253 Posts
Ed thank you for all your reporting. Wish you the best of luck in finding what is wrong with your car.
#29 |
I'm sorry I wasn't a better reporter this weekend. We had trouble and we were working on the car. I left this morning and dropped the car off at my sons. Going to dyno the engine and see where were at with that and go from there. Thanks for all the advice I got. Thanks again to Ed Wright for the box and the help. Ed
#30 |
Liked 574 Times in 212 Posts
Sorry????? no reason to be Ed. Thanks for your reporting. Good luck, hope it is something inexpensive...
Gary Hansen - SS/FA 4911, B/SA 4911 |
