Old 06-04-2012, 02:23 AM   #1
SSJ343
SSJ343's Avatar
Default Re: jerico 3-4 shift arm lever issue
I had debris between 3-4 slider and hub and broke this link. Bought new slider, hub and link. New link had more material around rectangular hole. New slider had also more clearance on hub, than old one. I have DR4 from 1999 and 10 finger dog rings.
SSJ343 is offline   Reply With Quote
Old 06-04-2012, 09:35 AM   #2
Robert Simpson
Liked 20 Times in 12 Posts
We have broken two of them. The first one was only after about 20 runs on the new trans. We figured it was something freak. So we replaced the arm and bought a spare. One year later in valdosta we had the same thing happen, this time when we looked closer it looked like a casting problem. It snapped the arm off smooth with the side of the trans. The shifting linkage was dragging on the ground. We replaced the arm and have gone on with things. That has been several years and many runs ago. We to have a long shifter on it. I hope it was just a freak thing that happened to you. Good luck.
Robert Simpson is offline   Reply With Quote
Old 06-04-2012, 10:16 AM   #3
Run to Rund
Liked 56 Times in 29 Posts
Did you carefully adjust the shifter stops?
Old 06-04-2012, 10:34 AM   #4
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
You're not alone gmonde. We have been fighting this problem for 3 years now. It was bad enough at one time that we had to bring extra shift levers to the track just to make it through a race. After installing a new one (3/4), it would immediately start twisting and eventually break. When we removed the nut and slid the lever off, the internal hole would be rounded out. Lever was tight, but still moved around. We been through every test imaginable and haven't found a cause. These are the NASCAR hardened, long shift levers. Long shifter, as well. Everything is adjusted properly. Similar situation. We've run the same Jerico for YEARS without fail, then all of a sudden, BOOM, problems around every corner! The one variable you might check is that your bellhousing is indexed properly. If the transmission is misaligned, it will put too much stress on the main shaft and shift forks (and gears), causing the need to use too much force when shifting. We should be out testing in the next couple of weeks. If we figure something out, I'll post it here. Might be time for a Liberty.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 06-04-2012, 11:20 AM   #5
69Cobra
Liked 2 Times in 2 Posts
I've broke one in the last 10 years. When mine broke my stop had loosened up and was not stopping the shifter, the slider/fork/arm was. After adjusting it on the bench with the cover off and seeing what its doing in there I've not had a problem since. But I believe the key is to set the stops with the cover off so you can see what you're doing. I set mine to where it leaves about .030" of play before "bottoming out" and let the dog ring suck the slider in the rest of the way. Haven't had a problem since. Also make sure your shifter rods are running as parallel as possible. Hope this helps
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 06-04-2012, 05:50 PM   #6
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
i have to ask ,,what lenght shifter (long has a short and long version)and what lenght fork arms are you guys running ???i am thinking the both long shifter and fork arms are creating to much leverage for the ecentric to handle ,,also double checked the adjustment
and mentioned previously the fork slides work perfect as well as the sliding 3-4 dog ring
thanks for your replys ,, still investigating gmonde
Old 06-19-2012, 04:41 PM   #7
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I installed my Long shifter last night and got the rods on when I remembered this thread...this sounds to me like a dumb question, but where are the stops? I don't see anything on the shifter that looks adjustable other than the heims on the rods. I don't want to take this thing to the track for the first time and bust the trans!
Paul Merolla is offline   Reply With Quote
Old 06-19-2012, 06:08 PM   #8
Rory McNeil
I have 2 Jericos with Long V Gate shifters (NON pistol grip), and if my shifters have any stops, I`ve never seen them.
NHRA 6390 STK
M/S 85 Mustang
Old 06-20-2012, 02:52 AM   #9
69Cobra
You know I've heard this before... I don't know if you have to tell them you want stops when you order the shifter or what. But I wouldn't use one without. Call Long and tell them you want stops on your shifter and see what they say. They might tell you to send your old one in and $100 with it for the upgraded shifter. I don't know but I wouldn't go banging gears without shifter stops or you are just asking for problems.
Kris Rachford
C/S 3032
Old 06-04-2012, 05:55 PM   #10
gmonde
gmonde's Avatar
the levers are not breaking its the ecentric that actuates the 3-4 fork thats shearing off ,,the bell housing was indexed thanks for your reply gmonde
