Liked 783 Times in 195 Posts
Yeah, Don't ever let anyone check your camshaft using a piece of masking tape wrapped around the balancer, a ball point pen to mark opening and closing and then measuring the distance between the marks to calculate duration.
Liked 880 Times in 311 Posts
I was told that the "NEW" Legal valve job did away with the unshrouding rules (1/8 bigger than valve head) and the 1/4" (Seat) part of the rule.
Basically if you can do it "On center of the valve guide" it will pass. It doesn't matter if it is in the bowl area or chamber area as long as it is "On center of the valve guide Center Line. The only exception I got, if you want to call it that, was when I ask if anything could be "elliptical" The answer I got to that was a definition of "on center". I'm pretty sure that last line just gave away who was giving me the Vale Job information. I would bet quite a few of you know his "Style"... of giving answers.
Adger Smith (Former SS) |
Liked 49 Times in 15 Posts
I have added a poll in the member's area, just for fun.
http://classracer.com/classforum/showthread.php?t=41556
Dean Feiock -- Stock 5002 |
Liked 9 Times in 8 Posts
Bump, this is 2 years old now.....so how far down with the cutter can we go? on both ends of the job?
Are they going by looks, feelings, a measurement or who you are? |
Liked 1,878 Times in 422 Posts
Ask your division tech people.
Alan Roehrich 212A G/S |
Bill, I have been told that as long as it swings around the guide C/L it will pass.
There seems to be no depth numbers any more. Let me qualify the above statement with "AS OF" July 2014. Rules can be a moving target you better call someone with a little more authority than this message board.
Adger Smith (Former SS) Last edited by Adger Smith; 11-01-2014 at 11:58 AM. Reason: sp |
Liked 1,439 Times in 301 Posts
Good call. Come out of nowhere and be fast at Indy. That is cool,but it is a lock for getting invited to the dance. Seen it many times. Most of the time it works out. Most of the time....
James Schaechter 3163 STK |
