Says he has the Camaro, and says he runs stick cars.
Ed Wright 4156 SS/JA |
that looks like an interesting combo though.
yep gotta be stick shift car, now theres a question run a 4-5-or 6? i know you dont have to keep same number of gears stock minimum of 4 correct? at least in this car's case. would you run a 4 or 5-6?
future superstock eliminator racer and gear banger.... ![]() |
Liked 1,893 Times in 423 Posts
Most run a 4 speed, for weight, size, drag, reliability, and simplicity.
In Stock, the transmission is supposed to be "clutch assist", meaning it requires use of the clutch to shift. Most common is the Jerico. You'll find that most 5 speeds that would be useful and useable will be illegal. Most, if not all of the engine programs are designed around 4 speeds, taking full true advantage of a 5 speed could require a different cam, headers, and rear gear, at least.
Alan Roehrich 212A G/S |
understood! thanks for the help. was hoping to be running a jerico anyway drove a car that had one WOW compared to trying to power through an old muncie or t-10 haha. kudos to the guys from way back when.
future superstock eliminator racer and gear banger.... ![]() Last edited by 283nova; 07-21-2012 at 03:48 PM. |
We just didn't know any better.
only older 4 speed i had any luck with was in a friends car was a dodge a833 with the slick shift" guts or whatever they used to be called. was hard shifting but that thing lasted a long time!!
anyhow, what are just some general ideas for the rear gears you guys are using in this type of combo with a 4 speed.
Nash 5 speed 5.87 gear. If you run an older carbed combo in GT you'r supposed to run a 3 or 4 speed ---Trevor
#8 | |
Cam Chowen 6067 1994 Camaro C/S |
