View Poll Results: Fuel injection? Do you run in open loop or closed loop | |||
Open Loop |
80 | 65.04% |
Closed Loop |
43 | 34.96% |
Voters: 123. You may not vote on this poll |
Thread Tools | Display Modes |
#51 | |
We are not illegal. I had went through an NHRA electronics teardown. And they had asked it I running open loop.
Art Leong 2095 SS |
#52 |
Open loop.
Unless you have an o2 sensor for each cylinder (with correction factors to support each cylinder) then you could argue some advantages to running it closed loop. |
#53 |
Liked 4,378 Times in 502 Posts
Open loop is probably better for bracket racing consistency I would think because the car doesn't adjust itself going down track.. however, would closed loop be better in a heads up run or when you need that extra power if the car is properly tuning itself downtrack? Has anyone ever tested to see which method was strictly quicker?
#54 | |
Art Leong 2095 SS |
#55 |
Art is right.
Ed Wright 4156 SS/JA |
#56 |
In my opinion the tuner should always have full control of the fuel map and timing .
But on the new cars from the factory the oem computer controls everthing . If its oem the the computer can control the car down track and its more consistenbut not faster . NHRA has allowed both , but if its a aftermarket computer the computer is not allowed to make changes going down the track unless the car came with a computer that did . I like were I have full control of the car bracket mode or heads up . I vote open loop
Bo Kenney |
#57 |
Unless the new Fords are different, from the factory they all go to open loop in P.E. (Power Enrichment) mode, or wide open throttle.
#58 |
Gentlemen,
The question of closed or open loop is not really valid when the engine is using a narrow band O2 sensor. The stock systems normally use this narrow band sensor that is accurate only in a very narrow target area of about stoichiometric (14.68:1 with pump gasolne).The wide band sensors can be used with the appropriate control system, but I would think you want absolute control to be consistanrt. Some of you racers hit it on the head, mentioning that at WOT the system had better be in open loop, using the base fuel tables with its modifiers. The operational parameters regardng PE and the closed loop threshold are probably the areas that are highly tuned (along with base fuel and spark), that the successful guys paying attention to. Forced open loop would cerntainly be my choice! Just an old racers two cents, Dennis Baccus Former F/S record holder - 1969 Z28, Current calibration engineer on GM MEFI systems and engine builder |
#59 |
There's an electronics teardown? I never heard that one before. Was this in stock with a TD or with the Neon?
Rob Lloyd 3728 BF/S |
#60 | |
But I passed.
Art Leong 2095 SS |
