Old 08-06-2012, 08:17 AM   #1
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Hardys Hangup Buick Crash!!!
Glad to hear that he's alright. Cars can always be fixed.
Jim Kaekel 3836 STK
Old 08-06-2012, 09:03 AM   #2
gcasey
Liked 5 Times in 3 Posts
Chris, glad everyone is fine. Scary! See you all at Martin this weekend. Let us know if you need any help.
GRC
gcasey is offline   Reply With Quote
Old 08-06-2012, 09:50 AM   #3
Lyn Smith
Liked 979 Times in 197 Posts
This should serve as a reminder to all racers to check that their push rod can not fall out the back of the master cylinder.Don't rely on the boot,or brake light switch to hold it in.On my new car i put a piece of light weight chain from the firewall to the pedal to restrict the backward movement of the pedal.I think alot of racers get in trouble when they change master cylinders,and the pushrod depth in the new master cylinder is different.
Old 08-06-2012, 09:54 AM   #4
Dick Butler
Liked 32 Times in 19 Posts
As Lynn stated it is the pedal movement which allows the rod to fall out if I am correct. Restricting the motion is the accurate answer or a longer rod.
Old 08-06-2012, 10:38 AM   #5
Dan Wilson
I have a 4 door body here if you need some parts.
Dan
Dan Wilson, STK3171, K/SA
Dan Wilson is offline   Reply With Quote
Old 08-08-2012, 12:09 PM   #6
Chris Hardy
Liked 4 Times in 1 Post
I'm going to fab up a rod retainer/guide tube. Looking under the dash, that looks to be best for this setup. Thank you all for your advise.
Take care
Chris Hardy is offline   Reply With Quote
