Old 08-11-2012, 05:57 PM   #1
rod
Liked 20 Times in 15 Posts
Default flywheel ?
i need a race flywheel for a different engine. my friend has a really good 40 lb Hays, for $90.00 since new 'wheels are so expensive........
what do you think about chucking the 40 lb'er in the lathe and cutting off 10 lbs?
i have a 30 lb Hays, and it appears to me that the 40 is just extra thick toward the friction face side.
your thoughts please.
thanks rod in AZ
rod is offline   Reply With Quote
Old 08-11-2012, 06:09 PM   #2
BlueOval Ralph
Banned
Default Re: flywheel ?
I used to have 40 pounders machined down to about 28 lbs they were cut from starting at about the dia of the crank and maching toward the outside leaving about a 1 1/2 at the od they act like a heaver wheel Hays called the scollped flywheels.
BlueOval Ralph is offline   Reply With Quote
Old 08-11-2012, 06:28 PM   #3
BillK
Liked 30 Times in 17 Posts
Rod,
Just remember that when you do this the SFI certification goes bye bye
Bill Koustenis
BillK is offline   Reply With Quote
Old 08-11-2012, 06:49 PM   #4
BlueOval Ralph
Banned
Rod you have a private message.
Old 08-11-2012, 07:16 PM   #5
Yep , can be done.. Some on the crank side as mentioned ,and some across the face.
It's hard to get a good surface on a lathe though. It'll chatter and vibrate. One problem is it's moving faster when you get towards the outside edge.
Finish it up with a flywheel surface grinder.
Old 08-12-2012, 12:01 AM   #6
rod
thanks for the help. it is hard to do things like this in a small town where nothing like this has been done before.
rod in AZ
Old 08-12-2012, 03:01 AM   #7
Run to Rund
Liked 54 Times in 27 Posts
check ebay. If you will accept off-shore steel (and after all no steel is still made here anyway), you should be able to find a cheap new wheel in the 30 lb. range.
