Liked 7 Times in 6 Posts
I have the stock bushings with the serrations ground off and they are loose for a factory bushing. I have stock control arms and stock ball joints also. The front end is glass and the weight was 1580/1220 with me in it.
One mod that really freed up my front suspension (79 Camaro) was the removal of the jobber ball joints and the installation of the low friction Afco ball joints. I used to be able to pull up on a front fender and release it and it would stay halfway up. With the new joints, there is zero friction keeping the front end up. which guarantees total front end travel on the launch. Track prep is certainly key, but 6" of travel up front for a 9" slick is very helpful to keep it stuck.
I'm not sure if it was your car or not, but on that video there's still a squack as the car launches. |
#3 | |
Do you measure travel by measuring from the fender lip to the ground static and then again just before the tires come off the ground? Last edited by Ron Gusack; 08-15-2012 at 09:28 AM. |
