#11 |
Liked 7 Times in 7 Posts
Great ideas here...some are...well..a bit un-realistic?
How about 1960 and later cars....or 1965 and later? Not sure about letting the '50's stuff in there... Are you ready for a '62 Nova Super-Mod car? Cam lift....somebody mentioned .700" max....another .550"...that's too SMALL! How about a compromise @ .650"...would require lower-cost valve springs than the higher lifts. I LIKE the following..... Single-disc clutch NO cranktrigger...NO belt-drive...NO vacuum pump....NO aluminum heads or rods..... Stud-mounted rockers...except Mopar engines... Could be "swayed" into 10.5 tire...although I think 9" could work.... Someone mentioned ladder-bars only...would allowing traction systems like Cal-Tracs or similar styles NOT be in the best interest of this class? Have a problem with clutchless trans....MUST be clutch actuated IMHO! Think small hood scoops could be allowed...or fibreglass hoods with scoops....Think that flat-hood ONLY rule would cause "identity" problem with Stock and SS cars...especially with the FANS.... WE DO want to put "fannies" in the stands....right GUYS? Anybody? |
