Old 07-09-2007, 12:06 PM   #4
Bill Harris
Liked 26 Times in 13 Posts
Default Re: Mustang Front End
Depending on the weight you were running, a cam and intake should help quite a bit. Your minimum race weight will be 3102 lbs in SS/CS with an automatic and that 311. The index for SS/CS is 10.65 so high 9's would to qualify you in the middle of the pack at most events.
You need to make sure the heads are NHRA accepted. Are you using N351s?
Bill Harris is offline   Reply With Quote
