#7 | |
Liked 503 Times in 131 Posts
Oh been there, done that: Assuming you stage the same way each and every time(shallow) and that you stage straight. I block the tree now with the visor, seems to help most of the time....for the driver part Other things that work but not always it depends upon how your car is leaving: Car related: Try one at a time if they seem rational at all: Lower launch rpm by just a tad rear tire pressure reduce a bit, are we using radials, or bias plias cars reaction time is affected. Add some weight to the car Add some suspension travel for the car Bigger front tire take some timing out might try a different launch engine temp.....car reacts differently at 120 degrees versus 150. Aircleaner.....with a rocket ship like the gremlin....its good for.02-3 by itself.....2-.3 in the entire run though. Driver: close one eye polarized sunglass attachment Move seat back Brake pressure gauge...have one and and figure out what pressure you leave at and go red.....then add a couple of hundred pounds..... You can still go red blocking the tree....especially if you creep. Eric
Eric Merryfield 1883 STK |
