Old 09-25-2012, 02:46 PM   #3
Dick Butler
Liked 32 Times in 19 Posts
Default Re: Converter Temp Effect on ET
Is the first round run on a cold car? Do you get the motor and trans and rear end run at all before the first run? Are you using any heavy oil anywhere which might be taking the extra time to thin out? Does the 60 ft show the change also or is it throughout the run? Is this something NEW for your combination? Do you have another Converter to try back to back?
