Old 09-28-2012, 10:34 AM   #1
sammy pizzolato
Liked 56 Times in 13 Posts
Send a message via AIM to sammy pizzolato
Default Re: LS1 + 12 HP Today....Automatic of Course!
hp should be the same in all cars with that combo unless it is a waggon or a stick.that is how it used to be.just saying!
sammy pizzolato is offline   Reply With Quote
Old 09-28-2012, 11:08 AM   #2
Tom Moock
Liked 10 Times in 6 Posts
1978 & 1978 350 malibu wagon got hp, twice, once with camaro & corvette and the next time with the camaro, but the corvette stayed the same, I don`t think there a malibu wagon that runs .50 under with 350. I would think the corvette, gto, firebird & camaro should all be the same hp. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 09-28-2012, 11:46 AM   #3
Todd Hoven
Guest
Posts: n/a
That's stupid, a Corvette has no advantage over an 04 GTO? Or an earlier nova that would the same engine ?
Old 09-28-2012, 02:37 PM   #4
junior barns
Liked 20 Times in 14 Posts
I don't know if that is what they are saying, but it is what I would say. I have seen some drag coefficient studies comparing these firebirds to corvettes to 69 camaro's to older mustangs and until you got above 135mph you didnt see any advantage! I would think a Nova would be real close to this also??
junior barns is offline   Reply With Quote
Old 09-28-2012, 12:16 PM   #5
Ed Wright
Ed Wright's Avatar
It was when Farmer was taking care of it. LOL
Ed Wright 4156 SS/JA
Old 09-28-2012, 02:49 PM   #6
69Cobra
Liked 2 Times in 2 Posts
If its the same platform then yes Camaro/Firebird, Mustang/Capri (for the years they made them) but if the platform is different for example wheelbase then no. I race a 69 Cobra with a 117" wb with a 428CJ. A Mustang with the same motor combo but shorter wb and physically smaller and more aerodynamic shouldn't effect my car even tho its the same engine.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 09-28-2012, 05:24 PM   #7
Ed Wright
Ed Wright's Avatar
So, you think the engine's HP should be altered to fit the car?
Like, if you choose to build the wrong car for it, you should get a gift to make your wrong choice more competitive?
If a given engine is under rated in one car, it's under rated in any other. I'm certainly with Sammy here.
Old 09-28-2012, 10:54 PM   #8
sammy pizzolato
thanks ED. it just does not make any sense for a corvette to be 45 hp less than a firebird or a camaro.is a firebird or a camaro better than a corvette.i don't think so!
Old 09-29-2012, 12:04 AM   #9
Stewart Way
Liked 70 Times in 22 Posts
So if you don't think the HP should be different depending on the the platform, should the HP for a given engine be the same for SS and GT? The GT car is just a different platform. If they should be the same, no need to have GT, just move them into the same lb/hp class. At least have same HP and index since the "platform" was the reason for the lower indexes in GT.
I agree there are some bad factors like the vette Sammy mentioned, but I still think platform is important to consider. Your as old as I am and likely remember the stink when NHRA decided to put the vettes in SS and do away with SP classes.
Or does the platform arguement only hold in stock?
Stewart Way 2424 SS
Old 09-29-2012, 11:11 AM   #10
Ed Wright
Ed Wright's Avatar
Stewart, most of the GT cars are drastically different. The GT Camaro/Firebirds aren't, but they are no longer the "hot set up". Many of those newer cars aren't actually built by the rule book. Look how many drivers can't even reach the dash, how many heads behind the B piller (rule book says they can't be), etc. Those are just Comp cars with no hood scoop. I don't, thankfully, have to race them heads up. I do think those should be rated differently. The conventional RWD platforms, I do not. It would be a mess to factor the jelly bean FWD conversions differently than other GT cars, and it's becoming all jelly beans in GT anyway. I really do think they are cool, just don't want to race them heads up. I sure would not build a Camaro/Firebird GT car and expect to run up front. If you do, congrats.
