Liked 129 Times in 59 Posts
So are we saying that the driver of the vehicle in question DID receive some sort of punishment for having an engine that didn't pass tech?
If the engine in the vehicle HAD passed the tech inspection the combination would have received an automatic HP increase, correct? Fair is fair! But what about his first-round opponent in Class eliminations? Shouldn't he have been reinstated after the vehicle in question didn't pass the tech inspection? Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 425 Times in 56 Posts
Do you all remember when the winner of National events was torn down. The only one who made out from that was the runner up, if the winner did not pass. And at Indy the only one who makes out from a class winner that does not pass is the class runner up. Been that way for ever. You should write NHRA if you feel it needs to change, not come here on a board and complain. I do not know of anything that has changed from NHRA because it was on this board. As for Brian Tilburg, He is as honest of a man as I have ever met. He said it was his mistake. Most people would come on here and make excuses. He mqakes tons of horsepower. I have set records with his engines and never had a problem. And so have many other people. Keep up the good work Brian, Thanks for all you do for us, Gary Parker
Gary Parker 1617 STK |
Liked 7 Times in 2 Posts
5 pages of comments, and I can't believe that nobody brings up the issue of applying HP to a combo for a run made in a mineshaft! How can atmospheric conditions be overlooked???
Chad Mahlosky 3225 STK |
Liked 10,781 Times in 2,241 Posts
Chad
I got Hp on Monday for a run made with a twenty MPH plus tail wind in Topeka. I ask Bob Lang after the run this question: "If I made the same run under idenical conditions at a points race to set a new record, would I get the record?" Answer: "No to much of a tail wind to set a record" .......and so it goes! If some goes 1.20 under they need to come apart, even if they have water leaking or light at the scales. |
Liked 316 Times in 67 Posts
20 MPH tailwind AT Topeka!
I believe you, Larry, I think Musta missed that one |
Been a head wind every time I've been there. :-)
Ed Wright 4156 SS/JA |
Liked 994 Times in 200 Posts
It can be a headwind one day,tail the next.I have witnessed cars picking up 2 tenths from one day to the next!!!
