We were worried about consistency until Pierce put together a string of .00 reaction times one weekend . ---Trevor
Liked 36 Times in 26 Posts
I don't believe that you can compare hydraulic Tranny fluid to the fluid that I use in my clutch system. If you are concerned about the temperature, then I would be more worried about, brake systems that use the type of fluid that you are concerned about. I have run a mechanical linkage set up, and done ok. I also have run a hydraulic clutch system, and I think that you just plain dont like the idea. You guys are great with the setup that you have and that is why you are Number 1. The person asked the question, and I was trying to show some good side of the system that I have. Sorry if I ruffled you feathers,
He asked for opinions and got it. If you have a hydraulic system and it works, great. Nobody cares which system anybody uses on their car.
Jeff Lee 7494 D/S '70 AMX |
Liked 8 Times in 7 Posts
seriously, i was told that, in stock (by a NHRA tech guy, i forgot who) that if the car was not equipped with a hydraulic clutch, i couldn't convert it...
is this possibly an IHRA thing?(that you CAN convert)
without losers,winning means nothing. |
Are guys running '93 thru '02 Camaro/Firebird using hydraulics in SS? Or does somebody fabricate mechanical pedal/linkage packages? Can't come through the floor, still has to be a swing pedal, right?
Ed Wright 4156 SS/JA |
Liked 130 Times in 20 Posts
Don’t worry you are not ruffling my feathers Maverick... We had a hydraulic clutch in my car when we originally built it and we are much happier with the mechanical linkage we have now. I was just trying to show the good side of what we use, as the title of the post says Hydraulic vs Linkage. You are right I just plain don’t like the idea of a hydraulic clutch.
I do applaud you for running a clutch car in SG, that’s pretty neat! Ed, Last I heard we still have to use the swing pedal and it can't come through the floor. On our 94 Camaro stocker we fabricated a bolt on linkage that used large heim joints that held the Z bar to the fire wall. You thinking of a stick in the LT-1??????
Brad Zaskowski 3697 STK, SS |
Liked 520 Times in 132 Posts
Do it Ed put the Jerico in over the winter!
The LT4 is a soft one, but has to be a stick.
