#41 |
Larry,
The rods are not custom length?? The center-to-center is the same as factory FE rods? I'll give you the fact the the rod is probably more reliable than the bigger rod end, but that's about it. When there are E/SA Mustangs that can run 10.00 at 3000' at Indy, I think you are barking up the wrong ladder. Rusty |
#42 | |
The guys that ran this combination, had pistons with a shorter compression distance to compensate the deck difference. Like said before by others, if they had removed the rod and piston, they would have been caught. ...and by the way, this same discussion was brought up on this forum many times, including this posting... http://classracer.com/classforum/showthread.php?t=8142 |
#43 | |
Liked 125 Times in 40 Posts
What E/SA Mustang might you be referring to? I only remember one at Indy in E, but it's wasn't the one that can run 10.00's in 3000 ft. of air. Care to elaborate on your scientific findings?
Sean Cour T6066 ladle Last edited by Sean Cour; 11-19-2012 at 10:18 PM. |
#44 |
Sorry..it was a 10.25 at 129 in E/SA a couple of years ago in 3000'
#45 |
That makes more sense. Rated at 285 back then, 312 now.
Sean Cour T6066 ladle |
#46 |
Liked 289 Times in 91 Posts
Larry
While you are figuring out all the frictional saving from the 2.200 journal from the 2.438 Ford journal, you also need to take into account that the Ford bearing is only .734 wide as compared to a Chev 2.200 bearing that measure .892 wide. Sounds to me like you not using all the pertinent info in your equation. By my figures it looks like there is 11% less drag with a Ford bearing for a 2.438 journal as compared to the Chev 2.200. Oh, my Crower rods are 6.488 in length and my pistons have the correct C/H number per NHRA. With that said I think NHRA should take about 10 hp off the FE Crower rod Combo. How bout you??? RJ Happy Thanksgiving |
#47 | |
NOBODY was "cheating" when the crank got submitted. I was not "cheating" when I submitted the rod...........I was trying to cover my own butt so my junk would not be illegal! NHRA gave the rod to all FE's in SS, and then later gave it to FE's in Stock. Nothing underhanded took place. It was all in the open and straightforward. Sorry if it pissed in your Wheaties, but that's the way it happened, and like RJ said, the barn door has been open on it for YEARS. NHRA is not going to tell racers "oops, you can't use rods anymore that you have used for years, because Larry Hill is pissed". When I sent the rod, I sent it in a box WITH a Ford rod right beside it. If they would have said no, it might be different, but they did not. Ford FE's were fast way before any kind of rods were approved. Do they live better? YES. Are they any faster? No. On the bearing surface issue, the FE has no chamfer, and is .730 wide. The 2.200 "HN" bearings are .830 wide. Do some of your math on the surface area, and you will see that there is not much difference between 2.378 (.060 under) at .730 bearing width, and 2.200 at .830 bearing width. The performance difference is not measurable, but it is a good excuse if you can't run with it, to say that the reason some Ford is fast is because of that "bogus" rod. It might be because some of us get up early and go to bed late to make our LEGAL junk go fast. Happy Thanksgiving! Blair Patrick Last edited by CaptCobrajet; 11-19-2012 at 11:40 PM. |
#48 |
RJ, you should get a hold of a set of those super trick Clevite "HN" bearings. I hear there is HUGE POWER in that .062 in width you are giving up there!! That should put you two car lengths ahead of Jeff Tueton's new car! LOL. Man, I hope we get those Honda rods soon!
#49 |
Liked 282 Times in 103 Posts
Whatever is printed in the NHRA accepted rod list can CHANGE quickly.
Last year,I was finally going to have an engine built with an accepted Crower rod for an Olds 455,and then it suddenly said: SUPER STOCK ONLY. |
#50 |
The difference that I see about the info on the rods is that your Crower rod listed for the B/B Olds(Super Stock only) shows "B.E. specify S.E. specify length specify custom weight" which is pretty vague.
The FE Crower rod shows "B.E. 2.325, S.E. 0.990, length custom weight 765 grms". You also have available to you a Eagle rod thats legal in stock with the appropriate dimensions. Eagle makes a great rod and I have run them in the past with a bolt upgrade and never had a problem, cost is around $500.00. You might also get Crower to add the missing data and then ask NHRA to approve the Crower for Stock also. Its for sure they won't just do it for you, so you have to invest some time and effort.. Or run the Eagles. Happy Thanksgiving RJ |
