Liked 5 Times in 3 Posts
what is the clarification as to what exhaust valve diameter is legal in the GM performance 401 replacement head, the head comes as a 1.88 diameter is this the legal valve size we can use in the 427-425hp engine, or do we have to use either the 1.84 or 1.72 valves? whats the answer?
Liked 30 Times in 17 Posts
The correct answer is start working on a new 2013 Camaro. Or look in the guide for the spec. That head also comes with 11/32 guides which must be opened up to 3/8 so the valve size it comes with is also subject to change to meet the NHRA spec for a particular combo.
Liked 58 Times in 18 Posts
Must use the 3/8 stem and 184 exhuast valve, also + 10hp when using this head.
If the valve sizes have to remain stock factory spec then why is there 10 hp added to the combination? All aluminum heads in 1969 were either 1.84 closed chamber or 1.88 open chamber why would NHRA require a 1.72 valve and still penalize the engine10 hp or 80 pounds extra weight in A/SA?
OK, I have 2 differint opinions now 1 for the 1.84 valve and 3/8 stems and another with 1.72 valve and 3/8 stems . Who is correct?
I see in the NHRA blueprint specs that when you use the 401 the 1.84 exhaust valve is the legal valve to use ........Ruler you were right , thanks
The iron head uses the 1.72 exh. and the 401 alum. uses the 1.84 exh and also you run at 435hp. with the alum. head 425hp with the iron head. Thanks
