Old 12-08-2012, 10:50 PM   #71
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Re: Records, Etc @ Gainesville
PS almost always follows the fuel classes, so they set up for that. They have the run data, to haul *** at that track"setting". As said above, when they test, its usually junk for us. All the fuel guys would strip the centers out of their tires, if they tried to run when ours is good.
2894 STK
Old 12-09-2012, 08:19 AM   #72
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Pro stock uses the clutch to get down the track. A sticky track slowes them down due to the drag on the tires. Loose is fast for them.
Chuck
C and W Racing is offline   Reply With Quote
Old 12-09-2012, 03:02 PM   #73
Ed Wright
Ed Wright's Avatar
Like I said, Mike told me he could not tell Topeka (which was great for us) from Tulsa which was slick for us. Had to change nothing.
Ed Wright 4156 SS/JA
Old 12-13-2012, 09:10 PM   #74
jmarkaudio
Originally Posted by Rollins_2241 View Post
Mark, If the bean counters aren't at least moderately happy, there is no place to race. So it's not a solution to say "the track should be a charity that is willing to lose unlimited amounts of money to make me happy". We're losing tracks left and right because it is not profitable in this economy to pay the note on the facility, much less double the spend on track prep. NHRA could certainly be a more efficient corporation, but that's another discussion. Once again, negativity is how you rationalize staying in the garage maybe, but it doesn't give us more or better places to race.
I don't expect the tracks to lose money, but if they don't provide what the racers as a whole feel is reasonable they will go to a track that does. SGMP doesn't seem to have a problem paying a normal purse and prepping the track properly. Speed Worlds track prep isn't the best, but the purse is comparable and the entry fee has been the lowest of any of the Florida tracks. And as far as Gainesville, the track is owned and run by NHRA, I doubt there is a note on that one. They could do better with it if they tried...
And the bottom line with any business is to satisfy your customers, otherwise you won't make any money or lose your business. It means they may have to tighten the belt in some cases to keep working, maybe cut back on those 500K salaries a bit... In this case, we are the customers. I'll go where I'm treated fairly. even if it means passing Gainesville on the way...
And last, we already have several tracks that have switched to IHRA in this state. IHRA must be doing something right.
jmarkaudio is offline   Reply With Quote
