12-19-2012, 01:58 PM
#34
Liked 17,488 Times in 1,595 Posts
Re: 2010 Mustang Stocker
Originally Posted by Damn Yankee
Ken, I was looking at the HP classification between the 2010 352 at 285, and the 2013 363 at 330 ? Is this correct 45 more HP in the rating for simply increasing the bore size from 4.060 to 4.125 ? Basically identical engines plus 9 c.i.'s ?
There are some differences in the combo's. The 352 is now rated at at 312hp for the auto. The 352 has a bigger intake valve, 2.06 vs. 2.02 for the 363. The 352 has 11 less ci, with a 4.06 bore vs. the 363 4.125. All other specs and parts are them same.
On its face the 352 looks to be better at 312hp vs. 330hp for the 363, but I can't tell you why it was rated at 330. I can only guess it was a consensus between NHRA and Ford Racing.
I think it is still a good combo even at 330. The valve size to me is a wash because of the bigger bore, you should get better flow into the cylinders with the less shrouding. I also think it might be a better choice at the present time because there are none out there, you would be able to control future horse power increases.
