Old 01-24-2013, 01:21 PM   #1
randy wilson
Liked 22 Times in 22 Posts
Default Re: 33 Spline
Moser rifle drilled, strange regular. 3100 lbs, 700 hp. no probems ever so far. They are. I believe a shade lighter, when drilled, then 31's.
don,t have one
Old 01-24-2013, 01:48 PM   #2
randy wilson
Also, no doubt the best axie, bar none, is Mark Williams. But I already had a strange spool set-up, so I went with strange, and, or moser. Moser is the only one who will drill 33's. Steve run's all Mark williams in the cobalt, 40 spline drilled. I just use the 33's because I have 3 center sections set up that way. Again, I personally have had no real problems of breakage, but strange does twist a bit.
don,t have one
