#101 |
Liked 23 Times in 13 Posts
Dan you have a pm
Frank Bialas 1570 STK |
#102 | |
Liked 2 Times in 2 Posts
You forgot one NHRA. I already make the corrections all you have to do is copy and paste it.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#103 |
Liked 64 Times in 11 Posts
Almost 30,000 views, poll, major safety issues and NHRA tech dept still ignores the stake holders! WTF?
#104 |
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 02-04-2013 at 11:49 AM. |
#105 | |
Liked 5,134 Times in 1,958 Posts
Seems to me,that's the way to approach this: You have to tighten the bushing too much to keep the rod from moving in and out when braking, staging...Thereby stressing the OEM rod until it breaks, as shown.
#106 |
Liked 101 Times in 52 Posts
Do you think this happened because the stiffer bushing didn't compress like the factory rubber one and caused the shaft to flex there? We had a car where the rubber one had cracked and moved which then was allowing the retaining washer to hit upon braking but never had a rod go like that.
#107 |
I agree!!!! Please send that if you haven't already.
#108 | ||
#109 |
Liked 26 Times in 13 Posts
Polyurethane does flex a little, surely not as much as the OEM rubber, especially a 40 year old rubber bushing, but they have a little give. However, a spherical bearing like the Calvert for the FoMoCo cars absolutely positively does not flex at all. So please explain why it is inadvisable to use a poly bushing while arguing to use a solid bushing instead?
The OEM strut rods were not designed to take the beatings they see when a 3500 lb car comes down from a 3+ foot wheelstand. Nor were they designed to maintain perfect alignment when someone stands on the brakes at 120+ MPH. As you can see in that picture, the Ford strut rods are necked down and threaded and the break is at the threads which are almost certainly cut and not rolled, making them weak (stress risers galore). Coming down from a wheelstand puts those rods in tension and if there is no compliance from the bushing the rods are going to be prone to breaking at the threads. The break in the picture has nothing to do with over-tightening the bushing as the portion of the rod that is being subjected to tightening tension is between the two nuts. I have the Calvert spherical bearing on a SS/GT 69 Mustang and I am seriously considering taking them off and replacing them with new OEM rubber. I don't think a solid bushing should be used with an OEM strut rod, especially 40+ year old units. Rather, aftermarket or custom made strut rods should be used that has enough safety factor designed in to make sure it can stand up to this sort of abuse. If this is about safety, then the last thing you want is a solid bushing.
Bill Harris ex 2172 STK ex 2272 S/S |
#110 | |
So, are you saying the break in the picture was caused by stretching, rather than flexing? Thanks
