Liked 10 Times in 6 Posts
What do you mean by "roll to the left"? Does the car drive to the left and you have to correct or does the car tilt to the left side?
If it is driving to the left, check the toe-in/out on the front end. Check the toe by raising the front 1/2" at a time all the way to the wheels coming off the ground. Be sure the toe alignment is not kicking out as the front is raised. That can make the car go left even though the steering wheel is held straight. |
