Old 02-18-2013, 04:04 PM   #1
Kevin McHugh
Default Air Bags
I have a Ford F250 crew cab (not a dually) that I tow a 28' enclosed trailer with. Trailer pushes the rear of the truck down when loaded which causes the front end steering to be light. Any suggestions would be appreciated. Some of our racing colleagues suggested air bags?
Many thanks in advance for your help.
Kev
Kevin McHugh is offline   Reply With Quote
Old 02-18-2013, 04:37 PM   #2
340Cuda
Liked 805 Times in 341 Posts
Default Re: Air Bags
Do you already have an equalizing hitch? If not I would try one first. If so can you tighten the bars any?
Bill
Old 02-18-2013, 04:39 PM   #3
FED 387
Liked 335 Times in 182 Posts
bags might help also check your hitch out might need to be adjusted up to make the trailer more level also redistribute the load in the trailer put more towards the rear of it
Old 02-18-2013, 04:57 PM   #4
Kevin McHugh
Thanks for your help. I do have the equalizer hitch and bars.
Kev
Old 02-20-2013, 10:05 PM   #5
fordteacherguy
Liked 160 Times in 51 Posts
I use Ride Rite air bags on my 1995 Diesel F-250. Love them! Firms up the ride, doesn't take much PSI to raise the truck to normal height. They sell the kit for a little over $300 on Summit. Well worth it.
I recommend separate (individual) air lines to prevent air crossover between bags on turns.
fordteacherguy is offline   Reply With Quote
Old 03-22-2013, 02:48 PM   #6
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
I have put air bags on every single truck I have owned.
Best money spent for towing safety... IMO (other than trailer brakes)
Equalizer bars are great as well.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 03-22-2013, 05:27 PM   #7
Kevin McHugh
Thanks everyone for your advice, very much appreciated!
Kev
