Old 02-28-2013, 09:22 AM   #1
Spyphish
Liked 679 Times in 180 Posts
Default Re: Hemi Head Ruling
Originally Posted by David Barton View Post
Our heads are simple. We cut them back as far as we can while keeping the original valve cover and intake bolt holes.
David Barton
#1. David, ya'll keep those in the trailers with the cars or back at the shop? I know, your a French model. Bon Jour
pitoyable
Old 02-28-2013, 10:57 AM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Distance from a line 90 degrees from end of front subframe rail to firewall from a point 12" above end of subframe rail. Distance between frame rails (a-body, b-body-fabricated, imaginary). Distance from spindle center to top or inner fender. Configuration of inner fender panel. Lots of good stuff here. Going to Houston. Will send more as I read it.
Jeff Teuton 4022 STK
Old 02-28-2013, 11:40 AM   #3
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
From hearing all of the arguments it sounds like the best fix is to get some formal training for the tech department of the NHRA. They need to take an approach like the NFL or NBA so that there is some consistency in how they go about enforcing rules in the handbook. Tech directors should conference call how they want to go about checking/enforcing rules and then put a written formal method of how to do that such that every division knows how things should be handled. From there training on this procedure needs to happen via online videos or classroom with some sort of test to verify the knowledge has been retained so all individuals doing tech inspections can be consistent division to division. The lack of consistency is what seems to be at fault and it seems as though there was no communication between divisions of problems as they come up. In situations were one division allowed something and another division did not, somebody needs to be contacted regarding that so that some consistency can be upheld. Also, racers surrounding that situation should be contacted to clarify whether there was a mistake on the ruling of not. I'm sure money is tight and none of the tech dept want anything of this magnitude but in the long run, it would help them.
I mean, if David was told one thing, Wendell was told another, and Charlie another, how could anyone expect that things would be consistent and there would be no repercussions
by telling three people in the same class different things when all three have engine programs that are centered around innovation? Anybody familiar with ESPN's "COME ON MAN" segment, it would be appropriate for this situation in regards to the tech officials involved..
So two things:
Get the ruling right in regards to the heads,
Tech needs to work harder to be more consistent.
PS: I want it to be know that all of I what I have suggested is waayyyy easier said than done.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 02-28-2013, 11:57 AM   #4
Bill Koski
Bill Koski's Avatar
Not a good idea to use major league sports as the template!
The NFL not so much, but it does remind one of the NBA where a personal foul by one player isn't a personal foul by another player or MLB where a strike is a strike for one pitcher or batter and isn't a strike for another pitcher or batter!
Bill Koski is offline   Reply With Quote
Old 02-28-2013, 12:25 PM   #5
Matt Welker
Liked 77 Times in 15 Posts
A request to the Stock and Super Stock Committee he been submitted for their consideration. The request proposes the creation of two classes in SS for running this combination, although not a specific solution on the classes or possible differences, which would need developed IF the proposal is seriously considered.
If, like me, you own a car and are interested in running a traditional combination following the SS rules and possibly returning to a real cross ram intake, while also allowing those with this combination free reign to turn the AH class into steel bodied pro stockers, my suggestion is to contact your SRAC representative or one of the S/SS Committee members found here: http://www.nhra.com/competition/committees.aspx and voice your opinion directly to them.
The fast cars already spin the backhalf of the track in killer air on non-national event prepped tracks. Next is spoilers (safety), R&P steering (has been lobbied for in the past), and it has to be easier to machine an AL head then create what is now allowed to be done to a steel head (and for a few days the AL head was legal for AH this year until that issue was reversed/corrected in the guide).
I'm all for letting the guys who want to run modified comp cars with this body style or steel bodied pro stocker versions of these cars. More power to them, and in their own class they can ask for all the changes they want or take the proven route of cheating/innovating/etc and then having the rule amended to allow what one group wants (intake before, heads now) but there should be an option for guys who don't want to cut their cars up, would like to retain the integrity and uniqueness of these cars under SS rules, and aren't ready to run Nostalgia races either.
-Matt Welker
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is offline   Reply With Quote
Old 02-28-2013, 01:23 PM   #6
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I run in SS/AH with my 68 Barracuda. When I started building the car the index was 9.90. then it moved to 9.80, then to 9.30. I hoped the car could run 9.30's when I started the build, this was in 2005. I have Barton heads that I bought used, dated 5/00, and a nice short block with Diamond pistons, etc. I enjoy going to Indy to support the class, but never built it to run with the big dogs. I can run 50-60 runs with the same springs and have run a few 8.90's, but mostly 9 teens and twentys. As long as you have shoe polish on the windows I can race with anyone, except for a heads up run, which I have had only one in 4 years. The point is you can race and have fun and not worry about all the go real fast stuff and worry about who has the lastest trick of the week. I do have another engine going together that I would like to be faster, but I do not worry about being the fastest. Now, if someone has to much $$$ and would like a place to spend it, please let me know. See everyone this spring. Dyno "Gold Coast Hemi"
Old 02-28-2013, 04:25 PM   #7
Liked 10,944 Times in 2,259 Posts
New prototype 2013 SS/AH cylinder head valve covers. Contact your local MoPar dealer for more info. Only offered in blue.
Zoomed out
Zoomed in
Old 03-01-2013, 12:35 AM   #8
Jim Bailey
Liked 584 Times in 94 Posts
Talking Re: Hemi Head Ruling
OK Larry, That's it !!!!!!!!!!!! David won't do it, so I will, I contacted Levi . The Amish Mafia is on it! Someone, (or somebody's going down, probably Teuton.)
Jim Bailey is offline   Reply With Quote
Old 03-01-2013, 12:36 AM   #9
KRatcliff
Liked 534 Times in 143 Posts
Or a Lewinski.
KRatcliff is offline   Reply With Quote
