#1 | |
Liked 184 Times in 113 Posts
Then then next quest to be the first 10 second Pure Stocker ![]() D |
Guest
Posts: n/a
No 11-second pass today but a better 12.22 @ 110 with a 1.64 60'. DA was 1369' and track prep was horrendous. Spun badly every time; could feel it when it left. Time for headers and a Pure Stock cam from Bullet.
#3 | |
Great performance even at 12.20sec, 110 is rockin for a Pure Stocker! Sounds like you left a couple tenths on the starting line ! 11's sure to come and a new National Record !! Brister ! Thanks for the information that helps a lot.. Love the fact that too many racers are afraid of foreign competition !! Har Har ( my Pirate laugh) They can't handle the TRUTH !! D Last edited by Dan Fahey; 05-05-2013 at 06:44 PM. |
Randall Cantrall (spelling ?) around Burlington / Piedmont area......
Dan the one i had is actually the one C J Mcdonald has now...
Danny Waters, Sr / 73 Duster "340" |
What would a pure stock cam be? Do you have an aftermarket cam now?
#7 | |
Guest
Posts: n/a
By the weigh (pardon the pun) finally got to scale it Saturday. Car is only 3135 (no weight savings at all done to it other than the wheels which are only 40 lbs. lighter than stock for all 4) and with me race weight is 3385 which is 110 lbs. heavy for B/PS. |
#8 | |
Was doing a lot of Crossfit and Russian Kettlebells but still ate prodigiously from hunger after aworkout just could not loose weight. Change the calorie intake and a lot of water for 6 weeks POW the weight came off. Now eating back normally with some changes once the weight came off. Now on the quest to lose car weight for F/PS but figure out how to lose 300# without taking it off the street. I love the AC too much after a Competition Run on a hot day ![]() AS for a Pure Stock Cam they have to meet all the Stock Cam Specs listed and use Stock Spring Pressures. Engine RPM is about the same as stock and they manage a few more HP. This is a perfect Class for either Flat Tappet or Roller Lifters and Stock Stamped Rockers. Especially Flat Tappet as you will not need pricy Lifters to keep an engine alive. Pure Stock offers a much higher reliability and it is a simple Cam and Spring change from Big Dog Stock. AND then you can run normal street gas and save a pile of money. Dan D Last edited by Dan Fahey; 05-06-2013 at 05:12 PM. |
You will probably find a larger gain with a set of correct ratio rocker arms then a blueprint cam. The stock rockers can be really goofy.
Guest
Posts: n/a
Who would be the best company to talk to about these? If I'm not mistaken roller tips are allowed now. ??? I've never even had the valve covers off so I don't know if the OEM ones are rollers or not on an LS1.
