Old 05-04-2013, 05:58 PM   #1
jerry witzel
jerry witzel's Avatar
Liked 44 Times in 15 Posts
Default Re: GM techs
In the underhood fuse box there is a place for a 40 amp j-fuse , it is labled stud 1. There should be a red plastic thing stuck in that position. Pull out the plastic and install a 40 amp fuse and you should have 12 volts on the red wire.
Old 05-04-2013, 07:08 PM   #2
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Ken,
Fuse should be on the top left of the fuse box under the hood. As Jerry said, it comes with a red dummy fuse in it. You have to remove that, put a fuse in, and you should be good to go.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 05-04-2013, 07:34 PM   #3
Kegracing
Got it. Thanks Guys!
Wonder why GM couldn't have just said that...
Ken
Kegracing is offline   Reply With Quote
