Liked 13 Times in 7 Posts
I would check your petal ratio. Don't assume anything without checking it. If the petal ration is correct, then to be absolutly sure on the master call Strange and ask them for the part number for a 7/8's inch drum brake manuel master.
If you can afford to, go ahead and change to 4 wheel disk. You will be glad that you did down the road. You can't properly drive the top end with drum brakes, plus the weight savings, etc. You won't have to purchase a second master later either. The disk need a 11/16 to 1 1/8 inch master. I run Areospace disk and they work well for the price. When you get your brake pressure guage you will learn a lot about your bakes and if they are working properly. Again check everything, don't assume anything. LOL
Richard Grant 4988 STK |
Thanks Richard! I will have to wait a year or two, before i can switch brake systems... If i can get it to run some sort of #, then, i will start on that kind of stuff... would love to have discs, on the front , atleast. Eventually, discs, all the way around, would be the ticket. My goal, is to make this the best car it can be, not necessarily the fastest...because , the latter costs alot more! hehe
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 54 Times in 27 Posts
For my 1966 A body with drums, I use Centric 130.62024 from andreotti@ottsfrictionsupply.com and I believe it is spec'ed to have a 1" bore. They also have Abex quality shoes that hold well and don't glaze stopping from 118 mph.
Liked 535 Times in 110 Posts
Don't waste your money on disc brakes at this point. Drum brakes work good and are treated like Rodney Dangerfield, "no respect". I pull my drums off every few races, clean and inspect them. Use premium, riveted shoes and good drums. I've run them for years on all fours with very little issues. I've found that car weight makes quite a difference. When I ran my car in E/SA or F/SA, I could smell that the brakes were hot, but that was roughly 3800 lbs. @ 120 MPH. Since I switched to D/SA and I'm weighing in at 3540 lbs., I don't smell them getting hot at all, even after braking from as high as 124 MPH. I wouldn't even think about using aluminum drums unless you enjoy playing Russian roulette. My .02.
Jim Kaekel 3836 STK |
#5 | |
