Liked 275 Times in 76 Posts
Does anyone one have a fix for loose press-in boosters? I found all 4 loose. Carb is a Holley 4180.
What is the going cost to have this fixed, and who to send it to? Thanks Sean
Liked 333 Times in 180 Posts
if they are not "too loose" you can try a little JB Weld to hold them in place--- otherwise most any of the REPUTABLE Holley rebuilders can fix that---they use a special 4 prong tool to stake them in place--- really they probabley need to be removed and machined flat (true) before they are staked so as to have a perfect mating surface!!!-- any RACE Carb guys in your area---??? no idea on cost tho
Liked 192 Times in 83 Posts
David Cook at DC Carbs.. fair, honest, quick turn-around, great stuff..
Liked 62 Times in 23 Posts
Sean, call Tony Tosto@ 314 660 5684, might be able to help.
BLP in Orlando. Or if you are close to Orlando I have a swedging tool..
Liked 24 Times in 8 Posts
Sean, give Bob Oliver a call: 775-331-5609
Don Anderson M/S 5342 |
Thanks for the replies. I am pulling my old carb out and will see how it performs. The carb with the loose boosters will go on the shelf for now.
Sean
