Just wondering if most people are running a transmission cooler on a C4 or are they looping the front to the back cooler lines?
We run a cooler in front of the radiator.
Liked 240 Times in 112 Posts
I use a cooler on mine now but years ago in a different car I looped them.
Dave Noll, EF/S ,?/SA 6526 |
Liked 227 Times in 74 Posts
Mine is looped together. All most 400 runs on this one, and I am not kind to it, lots of t-n-t days that I make 12 to 13 runs in five hours. I change fluid about 3 times during the season. This is a 5.0 stocker.
Is that with a deep aluminum pan or stock steel?
Cast alum deep pan with a differant filter pick up and run less fluid in it, a quart low on the dipstick. This is to keep fluid away from rotating parts and slowing them down. if that makes sense to you.
Of our three cars only mine which is the heaviest by far at over 3600 lbs has a cooler alex'ss car and tony's do not since switching fluids heat is no longer a issue for us
