Old 06-11-2013, 08:32 PM   #1
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Strange MSD Digital 2-step issue
Ken, you said you tested the 2 step, but did you actually put in on the rev limiter or just observe the light? Also do you have or have access to an MSD ignition tester? If you do try "running" it with the tester while working the 2 step switch, which I'll assume you have on the clutch pedal or linkage? Could it be possible you're "going past" the switch on the starting line, most guys seem to give a lot of leg to the pedal after they've fully staged. As Lew stated may be a good idea to make sure you're actually getting power to the input wire. Good luck Joe
Joe Buchanan SS/BX 3117
Old 06-11-2013, 09:17 PM   #2
Kens429
Kens429's Avatar
Joe and Lew, thanks for the response. I do have a McAmis switch mounted to the floorpan, and activated by an adjustable stop on the pedal. This stop is independent of the main pedal stop. The switch is wired in with a dash mounted light, which always works, running or not. I have not tested the blue launch wire yet, but is on the list. I repeatedly tried to simulate the failure that happens on the starting line, including your idea of pushing over center on the switch. The Gopro camera proved that the 2-step light was on, but the engine went right to the high side limiter. It is so strange that it only fails near the starting line.
Lew, I don't run the run retard yet, and haven't even plugged the computer to the box since year. It worked flawlessly until this Saturday. You may be on to something with the blue wire receiving 12 volts. I did a visual inspection, with all looking good. I did not test for 12 volts.
Thanks, Ken
Kens429 is offline   Reply With Quote
