Old 07-08-2013, 01:24 PM   #11
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Default Re: Smith Machine Ceramic llifters...
Originally Posted by B Aceves View Post
Hey Brent X 2 on the Shermans have well over 100 passes on mine no issues !!!
Used cam or not with a new lifter using a good BR fluid for a few passes will not hurt one bit and will make make you feel a little more at ease as well. Gibbs makes two different BR oils and works fine IMO.
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 07-08-2013, 02:01 PM   #12
Todd Hoven
Guest
Posts: n/a
Is a Sherman lifter just a limited travel stock lifter? I guess you have to cut way back on spring pressure with those?
Old 07-08-2013, 06:01 PM   #13
Liked 1,827 Times in 414 Posts
Originally Posted by Bill Edgeworth View Post
To my knowledge Trend does not make a Pontiac lifter. Pontiac lifters are the same diameter as a Chevy but Pontiac ones are taller. Putting a Chevy lifter in a Pontiac can cause the oil gallery to become exposed at the top of the lifter when the lifter is on the base circle and or the lifter oil groove to become exposed on the bottom side. I can’t remember which it is, it’s been a few years since I decided to see if Chevy ones would fit. I would just use the Sherman lifters. If you really want to use ceramics I have a used set. I quit using ceramics years ago.
I can ask them about that. I'm sure they can move the oil band if needed. They can probably make them taller, too. The price is reasonable enough that the upcharge would probably be as affordable as most anything custom.
Old 07-08-2013, 07:33 PM   #14
Adam Strang
Liked 96 Times in 23 Posts
I`m pretty sure the only difference between a Pontiac lifter and a Chevy is the placement of the oil band.It`s higher on a Pontiac lifter,you can get away with using a chevy lifter as long as the cam doesn`t have a small base circle.
Adam Strang 1018 STK
Adam Strang is offline   Reply With Quote
Old 07-08-2013, 09:22 PM   #15
brent flynn
brent flynn's Avatar
As Todd Hoven asked, will i need to run 130-ish on the seat? And what roughly , do these run, cost wise? They may be the way to go...do they lash, like a Schubeck? or do you preload them, a little?
Old 07-09-2013, 12:20 AM   #16
jmantle
Liked 172 Times in 81 Posts
Originally Posted by Jeff Lee View Post
Guys, if something is not in a catalog, pick up the phone and ask. It's not that difficult! PPP just made me a set of AMC TS lifters and there were none in the catalog. I just sent them a lifter I wanted copied and in less than 4 weeks had a set. Didn't cost extra either. Now it's available for everybody.
If I sat around looking at catalogs for availability while building an AMC, I'd never get it done.
Jeff, I understood SB Chrysler (pushrod oiling) are the same lifter. That's what I run in my 6 cylinder.
Jim Mantle
jmantle is offline   Reply With Quote
Old 07-09-2013, 12:25 AM   #17
Bill Edgeworth
Brent,
PM sent
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 07-09-2013, 09:17 AM   #18
Dave Ribeiro
Liked 56 Times in 27 Posts
Bill ,
PM sent.........
Dave Ribeiro 1033 STK
Old 07-11-2013, 11:28 AM   #19
B Aceves
B Aceves's Avatar
Brent, I would suggest a phone call to them and talk with them about the do and don't with their lifters he will talk with you and then you can decide what your comfort level would be with adjustment, spring psi , etc.
Bob Aceves,
746 E/SA
A&M motorsports
Old 07-14-2013, 02:02 PM   #20
brent flynn
Thanks Bob!
