Liked 121 Times in 11 Posts
Barry rumor has it that neither of us is the fastest H/SA in D-1 let alone at Indy. I am going to take a pass been a rough year. My ego can't take losing hahahaha. My money is on you if you go in H/SA. That is why I am looking for a soft EFI combo.
Joe DeMarzo 1317 STK |
Liked 4 Times in 1 Post
I'm gonna take a stab at this. The Third Gen Camaros mentioned above have a manifold with relatively long runners, which will make more power down low, and perhaps explains why you observed a harder launch.
Q-Jet manifold that I assume Frank and Lee refer to have much shorter runners, and should make peak power at a higher RPM, which probably accounts for the higher peak HP observed. If the comparison was made with identical manifolds and the same total area throttle body/throttle blades, and fuel curves both optimized to whatever extent possible, I'll argue that the FI has superior atomization, and should make a little more power at every increment.
Tony Curcio 1860 STK |
Liked 269 Times in 99 Posts
[QUOTE=
If the comparison was made with identical manifolds and the same total area throttle body/throttle blades, and fuel curves both optimized to whatever extent possible, I'll argue that the FI has superior atomization, and should make a little more power at every increment.[/QUOTE] Let's take an look at a ringer in the Mopar DragPak engine with the tall single plane and throttle body on top. Easily replaced with a carb. If the throttle body was flowed, a really good Holley was assembled to match, have a feeling that there would be little to nothing. Don't think there is any way to compare EFI to Carb in a stocker apples to apples. If you look at the potential of the combination with it's HP rating then you have something to study. Not being a dedicated student it appears to be a new car or a slow car.
#4 | |
Liked 13 Times in 9 Posts
Liked 319 Times in 68 Posts
Joe if you find a soft EFI combo call me!
Lee Valentine 1661 STK |
[QUOTE= That is why I am looking for a soft EFI combo.[/QUOTE]
Get a new Camaro or Mustang. Or call Billy.
