Old 08-12-2013, 08:52 AM   #1
Curt Rees
Liked 250 Times in 51 Posts
Thumbs up Re: Another Rear Suspension Issue
I think you are correct Jim. More then likely, the driver's side lower control arm front mount in the frame rail broke and let the arm slide forward.
I will know tonight. Thanks for the tip on the kits. "Christine" may live again!
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is offline   Reply With Quote
Old 08-12-2013, 10:13 AM   #2
Jim Kaekel
Liked 531 Times in 108 Posts
Default Re: Another Rear Suspension Issue
If that's the case, HR has what they call "frame braces" that weld to the front lower control arm mounting point to strengthen it. I think they offer them for "A" and "G" bodies.
http://hrpartsandstuff.com/
Jim Kaekel 3836 STK
Old 08-12-2013, 12:16 PM   #3
Curt Rees
The driver's side lower control arm front mount cracked at the welds allowing the rear end to move forward. The car is scheduled to go on the frame rack later this week to have the problem taken care of.
HR does make the needed braces for the "G" body mounts. Sounds like it is a common problem, especially on the Buick GN's.
Thanks for the responses! "Christine" should be ready to run again shortly.
Thanks
#5457
Curt Rees
Curt Rees 5457 SS
Old 08-12-2013, 01:04 PM   #4
Jody Lang
Liked 89 Times in 28 Posts
Also there are braces that connect the upper and lower front mounts.
Jody Lang is offline   Reply With Quote
Old 08-12-2013, 01:35 PM   #5
Curt Rees
Do you know who makes those Jody? Those are a solution also.
#5457
Curt Rees
Curt Rees 5457 SS
Old 08-12-2013, 09:20 PM   #6
2021STK
Liked 17 Times in 14 Posts
Curt, this is one link to the G-body braces:
http://www.umiperformance.com/catalo...roducts_id=350
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 08-13-2013, 08:58 AM   #7
Curt Rees
Dave,
Thanks for the information. That is the product I am looking for.
#5457
Curt Rees
Curt Rees 5457 SS
