#29 |
Liked 1,441 Times in 302 Posts
PAC Racing Springs are in to support the AStick and A/SA Challenge again this year!
Here is the deal.... Winners of A/Stick and A/SA will each get a gift certificate good for 250 dollars at jobber pricing for PAC Racing products purchased through PAC. If the winners use PAC products on the winning car and display their decal, they will receive a BONUS certificate for and additional 100 dollars on top of the 250! Runner ups in each class will receive a certificate in the amount of 150! PAC has a great variety of springs. Valve springs of course, but also suspension and other springs. I personally use PAC springs and work with them often. They make most of the springs that PRO Teams use, but they work with us sportsman racers too! Their RPM series is well suited for the abuse we give them in Stock, Superstock and Comp. As an example, I recently tested an enhanced design of their awesome 1409 beehive spring. It is a beehive like the 1409, but it has about 30 more lbs and the same spring rate. So for example, if a 1409 has 190 and 390 on pressure, the 1409x will have 220 and 420 at the same pressure. This spring also has more post production finishing and has a silver finish. The reason I bring it up is that it highlights the fact that PAC developed this spring in response to sportsman racer requests. They listen to the little guy and make us some great stuff! If you want to know more about this spring, you can contact me for more details, because it is not in the catalog yet, but I do have a link to their website. If you have not been there, check it out! http://www.racingsprings.com/
James Schaechter 3163 STK |
