Old 09-03-2013, 01:00 PM   #6
Curt Rees
Liked 251 Times in 51 Posts
Wink Re: Another Rear Suspension Issue
Hi Curt, you can replace the stock lower arm but not with an adjustable one. Although I have never seen it happen on a G-Body rear, check and make sure that you didn't twist an axle tube in the housing. That's about the only thing that I can think of that might not be noticable right away.
Billy,
The guru that you are, you were right on! The driver's side axle tube twisted in the housing. "Christine" will not be dancing anymore this year. The rear end is coming out and going to be completely rebuilt. I guess I will take the '96 Caprice LT 1 down to Thunder Valley and out to Oahe and run for a street trophy during the Midwest Class Racers show at both tracks coming up.
At least I will get to run something! If it goes down the track, it will break, not a matter of if, but when!
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is offline   Reply With Quote
