#11 |
Liked 120 Times in 11 Posts
Dwight, now we are getting somewhere. Strictly stock. Would the flat top with notches be worth carrying the extra 260 lbs? Rough HP number on a dyno, 10, 15, 20 HP less from the dish piston?
The flat with notches is a better piston but would it worth the weight? I am asking a lot without much info, lol that why class racers are the best!
Joe DeMarzo 1317 STK |
#12 |
In most cases a spherical dish will make the most power,However there are a lot of variables.Bill C.
#13 |
Liked 68 Times in 31 Posts
A dish also means more volume in total, a bigger bomb in theory
and we can fool the engine into thinking its got more compression than it really does.
Ron Mattson 5015 STK |
#14 |
Liked 5 Times in 2 Posts
joe I have 2 complete tune port 350s throttlebody to oil pans that I have run and dyno tested one is 1989 and one is 1990 all engine specs are the same except one is a flat top 4 valve reliefs and one is dish 4 relief when all testing and flogging was done there was only 2 or 3 horse power and and three or four hunderth different the only big plus is the 1989 is rated at 4 less hp we can talk more at etown if you want sorry about the grammar ok I am off the soap box gene monahan
#15 |
Geno I will look you up at Englishtown, Ron that is what I thought but was not confident in saying that.
Thanks.
Joe DeMarzo 1317 STK Last edited by Joe DeMarzo; 09-03-2013 at 09:01 PM. |
#16 |
Joe , Should I be bringing the 2 X 4 ???
Dave Ley |
#17 |
lol, you go to Indy for 10 days and I get loose... bring it I need a reality check again.
#18 |
Liked 319 Times in 68 Posts
I was thinking we could all chip in and get Joe a play station 3 to occupy him so he stops with these weird ideas. Still thinking about the 2 BBL.? Just busting them, see you at E-Town.
Lee Valentine 1661 STK |
