Liked 13 Times in 7 Posts
Rob, I will get a spark tester and noid light tonight and run the tests. I'll post results.
Thanks for the tips. Testing these systems is a lot better than starting to throw money at parts. |
Steve and SS 3011
Sunday when the engine was running, the fuel pressure was rock steady at 45psi. Also, the set up has a crank trigger and I have no knowledge as to the questions SS raised on the signal source and timing of signal. I'm hoping the problem lies in the coil, regulator or perhaps crank trigger as these are relatively easy (but not cheap) fixes. The tests Rob suggested will provide some direction. If this is an ECU based issue.....that's a whole different scenario!! |
Liked 11 Times in 8 Posts
I may be wrong but I seem to recall the digital 7's having an LED on them that when blinking during cranking indicate it's seeing a trigger (crank sensor input), you may want to read the instruction manual on that. If it's in fact the case and you're seeing it blink, that would indicate to me that the triggering is working correctly. I'm not familiar with your system but most merely piggyback off the MSD for RPM (trigger) events which it needs to operate. Would be a quick way of determining what side to look at spark or fuel. Joe
Joe Buchanan SS/BX 3117 |
Thanks. I'll check out the MSD instructions.
