Old 09-17-2013, 11:14 AM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Re: Intermittent no start condition
Spoke with the previous owner/builder.
The Accell Calmap only controls the fuel map. The other functions(timing, rev limiters etc) are managed thru the MSD box. Rich, this appears to be similiar to your set-up.
I wiil get a spark tester and noid light tonight and perform the tests that Rob indicated.
Is there a universal noid light or do I need to buy the kit that has injector brand specific lights? I believe my injectors are Bosch.
John Nechiporchik is offline   Reply With Quote
Old 09-17-2013, 11:24 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Ok, so basically the MSD is sending a tach signal to your EFI which it needs to indicate that in fact the engine is running. So you're still back to the basics, which can be indicated by a blinking LED, no blink, no start. I prefer the noid lights with a short pigtail on them so I can position it for easy viewing while cranking, if you have a helper this is a non issue. Look at your injector connector and get a light with similar terminals, as they've made a few different types over the years, there are some "universal" ones to chose from.Joe
Joe Buchanan SS/BX 3117
Old 09-17-2013, 11:40 AM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I have an MSD ignition tester and I just used it last Saturday.
It allows you to fire the ignition without running the engine.
It's a very handy item....but cost about $150 bucks I think
It can test the box, coil, chips and other items like a tach that is very often not accurate.......
Rich Biebel
S/C 1479
Stock 147R
Old 09-17-2013, 11:59 AM   #4
buzzinhalfdozen
YEP everyone running an MSD should have one of these. Mine is out of the toolbox nearly every race.
Old 09-17-2013, 08:32 PM   #5
John Nechiporchik
Here's the latest:
Tried to start car....no start
Checked rocker switch to make sure it was working...OK
Checked power to MSD box...OK
tried to start car...fired right up.....3 times....then returned to no start condition
LED working on MSD w/power on
Used spark tester to check coil output....OK
Disconnected crank trigger lead and , with ignition, shorted out green to purple wire which caused spark tester on coil to flash as the short was applied intermittently. This test was done per MSD direction. The only question I have here is that the spark was very weak from this test. Not sure of the correct level of intensity, but will call MSD again tomorrow.
None of the local auto parts stores had a noid light....Harbor Freight has a kit for $35, but I'll try to locate an individual tomorrow. The injector is a Bosch 80150756 with two flat blade terminals.
I hope to test the injectors tomorrow.
I appreciate all of your ideas and help. We WILL figure this out!!!
Old 09-17-2013, 08:39 PM   #6
John Nechiporchik
Correction: injector P/N is 280150756....Bosch30#
Old 09-17-2013, 09:41 PM   #7
SuperStock 1890
SuperStock 1890's Avatar
John,
Give me a call tomorrow later in the day. We had this at one time too. I will walk you through the tests. Call after 4. I have a charity golf outing.
Rich
You don't know what you don't know yet.
SuperStock 1890 is offline   Reply With Quote
