#28 | |
Liked 544 Times in 213 Posts
This is just not true and I have no idea why you would think this could be true.... A Battery stores energy.....and is a DC device...it has no components that can create noise and this mans' problem is either a wire connection issue or his ECU is at fault..... I had an Accel Gen VII ECU with a piggybacked add on datalogger in my '97 LT-1 Firebird.....It is probably still in that car and the car was number 2 in Division 1 last year....narrowly losing the Division title.... I ran it as I mentioned earlier.....with a Crank Triggger that ran outside of the Accel box.....and that is what was mentioned here as how this problem car is run.....The fuel pump and ignition run independent of the ECU......The ECU needs Battery connections.....and a switched B+ to turn it on.....It also needs a Tach signal from the ignition box..... If the ignition spark was confirmed to be there when the engine was not starting and the Noid light showed NO light at that time.....the problem is the ECU or the wiring that connects to the ECU to signal it to run..... Spark is useless without fuel...and the injectors need the ECU to turn them on..... The Optispark is not used...and the distributer is in there just to send the spark out from the coil.......just like any crank trigger fired race engine..... Sorry if I sould bitchy but too many cooks spoil the pot....and when I see someone suggesting that the battery is causing this problem I get a little cranky.....LOL If you want to really satisfy yourself as to what the problem is... When the engine is in the no start condition.....spray carb cleaner in the Throttle body while someone else cranks it and if you are able to get it to fire or even run with a steady stream of cleaner going in the t-body.........you have proved it is a lack of fuel....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 09-21-2013 at 07:15 PM. |
