Liked 27 Times in 14 Posts
Brad, just use the 4cyl springs. Thats all we have used on any of the stuff we have built. If its not making 400+ hp, it really doesnt make much of a difference.
AD> |
Liked 79 Times in 11 Posts
4 cyl springs work great! had them on my car, switched to a set of drag springs and the 60 ft's were a little better with the 4 cyl springs.
bob beals 7244 |
Liked 302 Times in 73 Posts
Thanks fot the suggestions guys but other than the initial stored energy that I assume helps weight transfer is there another idea behind doing this? Car hooks great 60's are very consistant.. im not looking for any more suggestions on which spring to put in the car just some help understanding the true concept.. if what ed said is the only reason this is done thanks guys!! But If not im all ears!
Brad |
Liked 33 Times in 16 Posts
Best answer is you are not going to know without trying it...what works for one combo will not necessarily work on another. I have never come across a guaranteed anything when it comes to racing.
You will typically have a smaller wire diameter and more coils to be optimum. The smaller wire diameter makes the coil spring "softer". This allows the weight of the front end to compress the car more at static height than the V8 springs it came with.
The purpose of having additional coils is to get the spring to recoil (if that's the correct terminology) once you launch the car. So you have this soft, small wire spring that is ready to recoil to it's free standing height once the car is launched. That will promote a higher front end height which aides in weight transfer & traction. Using a thicker wire will have the opposite affect unless of course your front end weight is much heavier. The bottom line is you need the spring compressed as much as possible and once you launch it recoils and off you go. Also, shortening the spring, any spring, for the "right" static height creates a stiffer spring rate and will not help the situation. I tried every factory AMC spring available from V8 with no a/c to 6 cylinder springs. I eventually went to a custom set and even that took a few sets to get it the right ride height and launch characteristics. A quality set of springs will last a very long time. A cheap set will not. Hope this answers your questions.
Jeff Lee 7494 D/S '70 AMX |
thanks Jeff! maybe we'll experiment down the road.. not having traction issues as of now but as we try and go faster this maybe how we have to get the power to the track..
