Liked 883 Times in 237 Posts
The secondary idle circuit pulls a small amount of fuel at idle but nowhere near the amount of the primaries.
I would call Quickfuel's tech dept. ,they are really good guys to deal with , and see if they recommend going larger on the primary idle feed restriction to allow more fuel in the idle circuit ,along with the smaller air bleeds. You may need more fuel than just going smaller on the air bleeds can provide, especially on the off idle transition to full throttle.
Liked 20 Times in 9 Posts
Thanks Tom,I'll do just that.
If it's a 4 corner idle carb the idle circuits should be mirrored including bleeds. If the secondary has a metering plate or is a 2 corner idle it won't. The SSR 780's I had through my hands were 4 corner idle.
If its the approved S/SS NHRA replacement carb , I believe it can only have the primary idle circuit adjustable , and has a non adjustable secondary idle circuit .
Not 100% sure on that , but pretty certain.
As delivered the secondary is adjustable with short mixture screws, they must be plugged once in competition. They supply lead plugs, much like the emission carbs had the idle screws plugged off. Not real sure why, it offers no real advantage having 4 corner idle.
#6 | |
I guess they wanted to make sure your not driving through the pits at a proper a/f mix if you drive different elevation tracks?
Jeff Lee 7494 D/S '70 AMX |
Jeff did you have any idle issues with your QF carb.if you did how did you cure the problem, i've seen your dyno video.By the way are you going to make the division race next week.
#8 | |
Their reasoning is the OE didn't have it so neither can you .
