Old 10-31-2013, 02:24 AM   #1
John Kissel
Liked 230 Times in 94 Posts
Default Re: LS motors and broken exhaust bolts
Thanks for the info. and suggestions. Asof right now all is quiet, and my hands have healed from changing plugs and wires. This poor truck has had to deal with the liquid salt that is used around here, and I can just imagine what more problems I could get into. Aero Kroil works miracles, just don't want to get greedy. John Kissel K242
John Kissel is offline   Reply With Quote
Old 01-12-2014, 07:36 PM   #2
John Kissel
I got a bulletin from Dorman yesterday about some new stuff they offer. Anybody use #917-107 exhaust manifold repair kit yet. It's a bracket that bolts to the back of the head and also pushes on the manifold where the broken bolt is. Thanks, John Kissel
Old 01-13-2014, 10:38 PM   #3
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Just did this job on my personal vehicle and used the new dorman manifold bolts. Some of the studs were still in tact with some shoulder sticking out of the head so they were easy enough to get out....but of course there were a few broke flush with the head....the bolt closest to the firewall on the drivers side. Get a handful of 1/2 inch and bigger nuts, clean the zinc plating off them with the grinder and fire the welder up set on kill. 3 attempts and it came right out. Not a great job to do, much easier with the plastic inner fenders out.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 01-13-2014, 10:45 PM   #4
CrateCamaro
Bolting that repair kit onto the back of the head is 10x harder then dropping the manifold. good penetrating fluid and a little heat they will fall off. I bought new manifold studs, doughnuts, manifold gaskets (usless because gm used an MLS style gasket that's re useable) and bolts. Made the job real easy. Im in the rust belt as well so I know what you mean when you say liquid salt. Much easier job in the summer, nothing worse then a car dripping on you when your trying to work.
1700 IHRA H/CM
1701 NHRA SS/?A
Old 01-14-2014, 08:34 PM   #5
John Kissel
Gee, Thanks. Of course these clamps are made in chikneeze, hope they get 1 1/2 cup of rice a day instead of just 1, so maybe they will fit. Just from how my luck goes, I'll try these as I'll only make my hands bleed a little compared to taking more of this rusty stuff off. Thanks, John Kissel
