Looking for a 1 3/8" diameter standard length 10 spline input shaft and throwout bearing snout for a SBF.
Can trade a SBF length 1 3/16" diameter 18 spline input shaft and snout (allows for use of a standard ID SBF throwout bearing and fork) or will buy outright. |
Liked 11 Times in 4 Posts
So, still looking.
10 spline Ford. Should be approximately 8 5/8" total overall length or have close to 6" length sticking out from the case. Learned that I can't use one from the late Version 4's. |
Liked 46 Times in 20 Posts
I have a New 1 3/8 input and bearing reatiner for the narrow gear. If you can use it give me a call 605-279-2827
Thanks Jerry for the info.
To further narrow down the search, the input that I need is for a wide gear Jerico. |
