Liked 71 Times in 38 Posts
I use a sealed bearing in my SBF. It was installed with green loctite. It may take some research , but I would think there has to be a bearing that would be close enough for your application.
Liked 308 Times in 103 Posts
I been using the sealed bearing for years,picked it up from truck pullers, Mc Leod, I think sales them Jerico used to I know they have them for Chevrolets,I don't know what your application is.
Had some made before,can't remember bearing # make bushing to adapt OD to crank BTW they fit in the bigger hole where converter pilot goes Remember made one for Windsor in pulling truck once. These bearings will last for years and if ever do go bad just go buy bearing and put in bushing. Mike Taylor 3601 |
Liked 333 Times in 180 Posts
YES McCloud sells the sealed roller bearings many types look on the web site
Liked 805 Times in 245 Posts
Thanks for the info. I run a 2.3 Ford motor with an adapter plate to run a SBF flywheel and bellhousing, the crank has been modified to accept the standard GM dimension pilot bearing so there is probably something off the shelf that would work.
Still wondering about gauling on the pilot. It would seem to me that there would be enough friction in the bearing seals that it would not turn free enough to avoid slippage and subsequent damage to the pilot. Might be overthinking this... |
BTW they fit in the bigger hole where converter pilot goes.
Hi Jim, I could not get the bronze pilot bushing to last even with the bellhousing aligned near perfect. I use the sealed bearing which inserts in the back of the crank where the converter nose goes. It clears and no gauling on pilot shaft. Looked great after 60 passes. High rpm launches are hard on those stock bushings I think. Happy holidays to you. Gary Howe,
Custom construction |
Never seen any problems,truck pullers are way harder on them than we are they bring rpm up high and then ride pedal for 50-75' depending on track.
Sealed bearing will end your pilot bearing problems Mike Taylor 3601 |
As long as we are on the subject of manual trans component life, how long are people getting out of throw out bearings? In my case, they are pretty trashed by the end on one season and due for replacement. The other issue that I hate is that they fling grease into the bellhousing. I've always just accepted these issue (limited life and the grease issues) as the cost of racing a manual trans. Any better ideas?
