Old 11-22-2013, 02:06 PM   #13
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: SBC Distributor gear
Jeff,
That method could get in ballpark, but oil galleys,oil groove on dist. are'nt really located that close,to where I would use them that way.
Usaully I will place dist by checking the way the gears mesh together,I want them running where it meshes close to center on dist gear teeth and feel just a little bit of lash between gears.
You can check pattern on gears with grease or gear marking compound if need to
Mike Taylor 3601
