#11 |
Liked 888 Times in 239 Posts
A lot of cars built in the late '70's and into the '80's that were built around a tire like the 12.2x31.25 or the older 14x32's are running the Hoosier 31.5x12.5 DO5 tire.
It's a stiff sidewall tire. Check the website for the size info. http://www.hoosiermidatlantic.com/su...subCat=2&cat=1
#12 |
I also take it ,No Tubes !
#13 |
Definatly tubeless.
Saves at least 12-14 pounds of rotating mass.
#14 |
Don't be afraid to try a narrower Hoosier if that's all they make. The traction is better.
Ted Barnes 1511 HR |
#15 |
yea my car was put together in the mid 80s,not afraid to go to a smaller tire if traction is better,not really to much issues with the good years,they do have tubes in them,i put 2 sets on the car since I own it,
#16 |
Liked 45 Times in 32 Posts
Mickey Thompson....
#17 |
Sorry forgot about Mickey T.
#18 |
Hoosiers, I usually get ~125-150 passes on my S/C dragster then the 60' times become inconsistent.
Bill Baer 3391 SC, 339B SC, QR |
#19 |
Neither
Mickey Thompson ALL the way, I used to have Hoosiers on my dragster, and I made the switch to M/T my car got WAAAYYY more consistent. Then my father had switched from Goodyears on his Vega, and got a set of M/T on the car, first race, was in the finals. I will give you one good reason why M/T are superior, if you wanted to go in the 7s with a 10.5 radial tire, which tire brand would you choose? (EVERYONE runs a M/T) and you want to run on the stop with a 14x32 or a 16x33....Mickey Thompson all the way. |
#20 | |
Doug Humes S/G 3880 |
