#1 | |
Liked 319 Times in 82 Posts
I also paid a lot of attention to how I was setting his tires in the water and how it affects the burn out. After all the research I did watching stockers I think our plan is to stop about a tire roll to the edge of the water and when given the signal bring it to the waters edge and let her rip. I have seen some guys spin the tires then drive outta the box to do the burn out but to me it seems like that's a good way to sling water up into the wheel wells only to drip on the tires while staging. I have also seen a lot of guys not get the tires wet enough and struggle to get them spinning. |
Liked 1,439 Times in 301 Posts
The big thing with the burnout. You need to get the tires wet and move to the edge. It is also important to have the rpm high enough and to snap the clutch quickly to shock the tires loose. Some try keeping the rpm low and easing the clutch out. They think it will be easier on things, but it will probably just slip the clutch instead. Also, you need to be quick to clutch it out of the water to keep the engine from pulling down below the rpm where the clutch will slip.
There are times to keep the rpm up and burn hard forward if there is some water ahead of the box and you want to get passed it with assurance the your tires are dry. Keeping the rpm up during this point keeps the clutch from slipping too much also. It will take practice, just be careful and have fun!
James Schaechter 3163 STK |
