Liked 80 Times in 28 Posts
Bobby
Chances are it has a factory 3000 - 5000 lb hitch on it but there are some areas to look at before hitching up Few things to consider -length of motorhome/overhang (can affect handling) -beef of frame to the back bumper? - I think Ford has 16" rims/Chev should be 19.5" (better tires and less sidewall) You will want to consider boxing/beefing the hitch both to prevent chassis flex and Motorhome Delamination as well as peace of mind that the trailer stays attached ![]() The last two years I towed with a '99 Chev chassis (31' Motorhome) 454 vortec and a 4sp 4L80E towed a 20' V nose with a Super Stock car with no issues Feel free to PM me for more details |
Ok the Chevy is 30' long and the ford is 34' long. Can I take it to a shop to get a stronger hitch put on? Also, what are the most common problems with motorhomes and what should I be looking for as soon as I get in it?
Liked 320 Times in 119 Posts
Call John at DRC race products 570-658-3515. He did a great job on my old motorhome hitch, his craftsmanship is a work of art.
Bobby,
Look for the following * Any Delman? Roof in Good Shape? *Open every compartment and feel around the roof for soft or wet spots *Exhaust Manifolds - Make sure no leaks or broken studs *Try to test all appliances Fridges, AC's etc. are very expensive to fix You can beef up the hitch. Not a big job. The less overhang the better. The bigger the tire and weight rating the better |
Thank you Mark.
Liked 459 Times in 90 Posts
Bobby call me. The coach I use has a redone hitch. You can see it in coatesville.
Bob Bender 144 O/SA 2010-2012 National Record Holder |
